Twins support bracket
Smarty Stacking ?
Phat Shaft turbo users
Whats a good way to support my HT3B on my twin setup. Should i just come off the block with some strap steel and bolt/weld something to the hot pipe flange? Or should I try and bolt to the 3B somehow? Any pics would be great. I looked at RIPS bracket for his S400's on the web and really couldnt tell what they were doing there.
If you'll pm me your email address, I'll send you a couple pictures of my bottom bracket. I welded it to an elongated flange i made for the oil drain. If you need a flange, I think I have a couple extras.
Ron
These are some good ideas! I bolted a piece a metal to the block (existing M12 holes) then welded a piece from the oil drain to it. I like the idea of going up to the hot pipe bolts better though, it's a straighter angle and will support more.
Jim
How about something like this. I drilled a hole between the mounting bolts and welded a 1/2" bung for the oil return before install (not in pick). #ad
HTH
Max
