mattymac said:
Thats one of the cleanest set ups ive seen. Also that valve cover is BAD A$$! I think with the MLS gasket and studs you should be able to be deep in the 70 psi range. What are your temps with your set up now?
I have only logged about 50 miles since the install, so the following info is based on very limited history.
EGT Temps act totally different than the DD Jammer I was running prior to the twins. This setup climbs to 900-1000 degrees very quickly, then stays there until you really push it. From 25 psi of boost up to 35 psi of boost, the EGT's can climb as high as 1150-1250 degrees, but at around 30-35 psi of boost, the HT3B is spooled, and as you push the truck harder and the boost rises, the temps start coming down. Last night I was talking with Piers and he told me that the 3B doesn't start doing its job until around 30-35 psi of boost. So I went to a local hill that is probably 7% grade and 1/2 mile long. From a dead stop at the bottom the temps rose to 1000 immediately and stayed there pretty much as I shifted 2nd through 6th gear, then as I stayed in it in 6th, the temps rose to 1250 degrees and the boost was around 35 psi, then as the truck really began to pull hard, and the boost reached 43 psi, the EGT's had gone down to around 1100 degrees. At the top of the hill, the truck was doing 100 mph, the EGT's were 1100, and the boost was around 43 psi. Keep in mind that the numbers are not exact, as I am recalling the numbers as best I can since there was alot going on at the time, and the numbers were changing extremely quickly. Also, we are at about 4,600 feet here in Logan, Utah.
I found it interesting that above 35 psi, the EGT temps actually began to decline. Anyway, I will slowly work my way up to 50 psi, and work the TST box up from 4/4. I am a little gun shy since I blew up two singles with the TST box prior to going to twins. Piers says the twins will handle the TST and up to 70 psi. Currently he is running 60 psi with the stock head gasket and studs. Wonder how far the stock head gasket will go. I think I'll stay about 10 psi below Piers as he works his way up the psi ladder.
As for the SouthBend Con-Fe, it held up extremely well. It didn't slip at all, and wasn't hard to shift after handling the drags up the hill. Like I said earlier though, I have only put about 50 miles on, so we'll see if the clutch holds up, but so far so good.
Peter
