1. How does one extend the length of the Borgeston shaft? Is a lot of force required or does something need to be unscrewed? Mine came out of the box shorter than the stock Dodge shaft.
2. The Boregson rag joint has some bolts and screws in the kit. Are they used in our Dodge application? The original setup has backing plates that only fit the existing Dodge screws.
Thanks,
Thanks,
