I have a question regarding how “slippy” the center slip joint in a two-piece drive shaft should be? My 2001.5 3500 (5 speed, RWD, 205,000 miles) has developed a little “tunk” sound / feeling that randomly occurs just after the clutch is fully engaged and the truck is accelerating during a start in first or second gear. Looking things over from underneath revealed no visible slack in the u-joints, the axle u-bolts are tight, the center bearing runs smooth though the rubber is deteriorated, the rear end (posi) has a little play in it but nothing too outrageous. So I had no specific evidence as to what the problem is. I hate throwing parts at undiagnosed problems but given the mileage on the truck and browsing the TDR forums for guidance, I ordered three u-joints and a center bearing and set to work.
With the shaft out on the floor of the garage it took 45 minutes of careful to moderate (OK, some heavy) hammering to separate the rear shaft and slip yoke from the “slip” joint spline behind the center bearing. The rubber boot covering the joint was good, there was grease on the splines and there is little apparent corrosion on the shaft / yoke splines. However, the blue plastic coating material on the rear facing male driveshaft splines was peeled loose on two of the spline ridges. I believe that was the cause of the bind that required the extensive hammer massage to get the two shafts separated. I shaved off the loose blue material and relubricated the splines. At this point the slip yoke/driveshaft spline joint is still *very* tight and don’t want to continue the shaft rebuild until I understand how much and how easily the slip joint should slip. Given that the front half drive shaft is only positioned in-place by the center bearing and its relatively delicate rubber suspension, it would appear to me that any front/rear motion of the rear half of the shaft (during reinstall and on the road running) must be handled by a very slippery mid-shaft slip joint. I avoided applying heat to the slip joint to separate it initially so I wouldn’t damage the blue coating. The coating either deteriorated over time or when I separated the slip joint. The only sure thing is that it was frozen tight on removal. What is the function of the coating? Can it be scraped or peeled off and the splines run directly greased with no ill effect? Please give me the benefit of your collective wisdom and experience regarding what I can reasonably get away with regarding my non-slipping slip joint. I would like to get another 5 years or so out of the truck without forking over the cash for a new driveshaft assembly if I can. Then I can find out if I chased the “tunk” away or if it’s really going to get expensive (clutch disc internals, rear end, etc.)
