Engine/Transmission (1994 - 1998) Two wheel low kit
Engine/Transmission (1994 - 1998) Timing Pin
Mine is a 99 5 sp manual, quad cab, long bed, knob color (don't care, but if I had to choose, red), probably shifter mounted, but again, don't care. I hope this make it easier in your matrix. ;)
Bob,
I'm interested. '97 auto regular cab long bed. I would be interested in mounting it probably in the airbag module cover,depending if it will fit there. Black knob for me. Email me you number and I'll call you if you want me to get you dimensions in there. Thanks
vc
Thank you everyone for your patience. Here is the status of the shifter mounting bracket. Because the lever sits in a recess, there is not enough room to the front or sides of the shifter. The problem with mounting the valve to the rear of the shifter is that the valve hits it where it bends towards the rear. In order to get it to fit I will have to lengthen the mount 1. 5" and mount it towards the back. When the shifter is in low range the valve would rub on the rubber boot, I was able to push the boot down to were it is below the bottom of the valve and solved that problem. I hope to get a bracket finished tomorrow and installed on a truck so I can post a picture. Please email me so I can easily keep track of who wants what. Some of your handles and email names are different and I am trying to keep them all straight. Thanks again. Bob -- email address removed --
Here is a photo of the shifter mount for the '98-'01 trucks. As you can see the tubing is not there, but you can get an idea of how it will look. If anyone who wants a kit does not recieve a conformation from me by Monday,please let me know.
Bob Verhoef
This comes under the heading of "GottaHave".
2000 6speed, like where you mounted the control,
Black would be just right.
Where do I send the check??
BTW, great job, simple and elegant.
Rodg in Bellevue
The valves are here, and the kits will start shipping this week in the order that the checks were received. There are some kits left if anyone else wants to order one. As requested here is a copy of the instructions. Although not complete, it should answer some of your questions.
Thanks
Bob Verhoef
Tools needed
Drill motor and 3/8”drill bit (’98-’01 shifter mount)
3/4” hole saw or flat blade wood bit ( ‘98 -‘01 consol mount)
Allen wrenches
Razor knife
Tape measure
7/8 end wrench (consol mount)
This kit includes:
Manual Valve Assembly (valve, three push connect fittings, two vent filters)
Black Nylon Tubing
Split Poly Loom
Mounting Bracket (for shifter mounting only)
Grommet (98 - 01 shifter mounting)
Vacuum Hose Cap
Tie Wraps
Safety Instructions
Please use caution when working under or around your vehicle. Set parking brake and block wheels if necessary.
WARNING!
This kit is intended only to aid in low speed maneuvering. The increase in torque to the rear wheels when in two-wheel low can cause damage if misused. Do not use on rough terrain or above 1300 engine RPM. We will not be responsible for damage do to misuse of this kit.
Operation
This kit allows the front axel to engage-disengage by the manual valve. The transfer case shifter will operate the same as before with the exception that the manual valve needs to be pulled out to engage the front axel. The switch for the 4WD indicator light is located on the front axel. The light should only be on when the front axel is engaged. To engage 2WD low simply shift the transfer case shifter into 4WD low and leave the manual valve in. (4WD light will not come on) To go from 2WD low to 4WD low pull out on the manual valve. (4WD light will come on) To go from 4WD low to 2WD low push in on the manual valve. (4WD light will go out) To go from 2WD high to 4WD high shift transfer case to 4WD high and pull out on the manual valve. (The 4WD light will come on) To return to normal 2WD shift the transfer case to 2WD and push in on the manual valve. (the 4WD light will not go out until the manual valve is pushed in) Always move the shifter first then the manual valve. When the transfer case is in 2WD the manual valve should be down. It is best not to pull out on the manual valve until the shifter is in 4WD.
Instructions
Step One
Verify the operation of the four-wheel drive indicator light. Shift the transfer case into four low or four high and check for the dash light. If necessary drive the truck back and forth until the light comes on. If the light does not work repair prior to proceeding.
Step Two
Remove the shifter boot(s).
‘94 -‘97 manual and automatic - remove the Philip head screws that hold upper transmission and/or transfer case boot in place.
‘98 -‘01 manual - remove the Philip head screws that hold the upper transmission shifter boot in place followed by removing the transfer case boot by gently squeezing the sides of the boot while pulling back and up.
‘98 -‘01 automatic - remove transfer case boot by gently squeezing the sides of the boot while pulling back and up.
Step Three
For Shifter mount 98-01 manual and automatic transmission
Refer to step four instructions with the exception that you will need to drill and deburr a 3/8 hole in the floorboard to the front of the transfer case shifter mount. Refer to diagram “A” for location. Install the supplied grommet in this hole. Run the tubing through this grommet and between the transfer case shifter shaft and boot
For Shifter mount 94-97 manual and automatic transmissions
Refer to step four instructions with the exception that you will run the tubes between the shifter shaft and both the upper and lower transfer case boots.
For console mount 98-01manual transmissions
Remove the consoles six 5/16 hex screws that hold the console in place. There are two screws under the transmission shifter boot and two screws under the transfer case shifter boot and one each under each of the cup holders rubber coasters. Choose either top or back mounting. See diagram “B” for hole positioning and drill the 3/4-inch mounting hole. A hole saw or flat blade wood bit are recommended. A regular twist drill can bite in to the plastic and could cause damage to console. If end mounting, pull the console up enough to access for drilling. Use an Awl or other sharp pointed tool to make a hole in the flat part of the transmission boot. See diagram “C”. Run the tubing through this hole.
Step four
Push the first black tubing through the path described in step three. Go under the truck and pull through enough tubing to reach the transfer case valve connector. This connector is located on the top of the transfer case and has four black vacuum hoses coming out of it. The other end of these hoses is connected to black, white, red and green colored tubing. Remove the connector from the transfer case by pulling up while gently rocking back and forth. Using diagram “D” as a guide, cut the hose that the light gray tube is connected 1 1/4” from the base of the connector as shown. Connect the new tubing to the hose that is still connected to the light gray tube by inserting the tubing into the hose approximately 3/8”. (wetting the tube will ease insertion) See diagram “D”. Connect the other end of this tubing to port #1 of the manual valve (supplied). Leave the valve loose in a convenient location for now. The connectors on the valve are push to connect style. To install the tubing simply push the tube into the connector hole until it stops. To remove the tubing push in on the ring around the tubing at the end of the connector and pull out on the
(continued)
tubing. Do not be concerned about tubing length at this time. Insert the next tubing through the hole and connect it to the other end of hose that goes to the transfer case valve connector that the light gray tube was connected to. See diagram “D”. Connect the other end of this tubing to port #2 on the manual valve. Insert the last tubing through the hole. Back under the truck, remove the hose at the connector that the red tube is connected to. See diagram “D”. This hose might be hard to remove. If necessary cut a split in the hose over the barbed nipple next to the transfer case valve connector, cut off and discard the split end. Cap off the barbed nipple with the cap supplied. Connect the last of the new tubing to the hose that the red tube is connected. See diagram “D”. Connect the other end to port #4 on the manual valve. Reinstall the connector by lining up the two indentations on the transfer case valve connector with the two posts that stick up from the transfer case valve. Make sure all the connections line up then push down while gently rocking back and forth. Cut the supplied Split Poly Loom to the proper length and cover the new tubing. Tape or tie wrap out of the way.
Step Five
Check operation. Start truck and shift into either four high or four low. Lift up the manual valve knob and drive the truck back and forth until the four-wheel drive dash indicator light comes on. After the light comes on push the manual valve knob down. The light should go out. Shift back into two-wheel drive and pull up on the manual valve. The light should not come on. If the system does not operate correctly recheck all the hose connections as shown in diagram “D”.
Step Six
Shifter mounting
Mount the shifter bracket on the shifter. Determine an orientation that works best for your application. ’94 -’97 can be “clocked” in almost any direction. ’98 -’01 manuals can only be positioned at 6 and 9 o’clock. The autos can be positioned at 3, 6, and 9 o’clock. The bracket should butt up to the bottom of the shifter knob. After the bracket and valve are in place and you have checked that there is no kinking or binding of the tubing in any shifter position, the hoses can be shortened. Using a razor knife cut each tube, one at a time, to the proper length. Tape or tie wrap where necessary. The connectors on the valve can swivel for orientation. The stem on the manual valve is not centered and the valve may have to be rotated for proper clearance. Note that the knob set screw has been “locktighted” for shifter mounting applications.
Console mounting
To install the valve remove the knob. Thread the first brass nut on the threaded stem of the manual valve, leaving 1/4” thread above it. Place the valve stem in the mounting hole that was drilled earlier and thread the second nut on the shaft and tighten. The top of the nut should be flush with the top of the shaft. If not, adjust first nut. Using a razor knife, shorten the tubing at the manual valve to the appropriate length when the consol is in place. Note that the connectors on the valve can swivel for orientation. The stem on the manual valve is not centered and the valve may have to be rotated for proper clearance.
Step Seven
Reinstall the console and/or shifter boot(s)
Well Bob I am going to put the lock out kit to the test this weekend. Have to back the 5er up a long hill. I will let you know how it works.
Mike
Hi Bob;
I have the electric operated valve in mine,. but yours sounds mich better. Is it cable operated? I have a 96 RAM 2500 that I have converted to dually with a 5 speed. Got tired of replacing automatics. $$$. I'm sure that all is the same in regards to measurements etc. I'll need two kits when you can get around to it.
208 687 3579
jbrowne
