Did anyone buy this? How does it work?
Thinking of adding it to mine.
HLewallen said:- there is a bus line between the Uconnect module and the radio,
nriver said:I dont think the included wire was long enough, that is easily fixed though.
Getting the Mirror control would be cool, have not looked to much into that.
HLewallen said:I have it (factory installed) and think every car should have it. I am keeping the factory radio because of it. That is an important thing to note - there is a bus line between the Uconnect module and the radio, so as of right now I don't think there is any way to keep the Uconnect functionality with and aftermarket head unit. I am still trying to figure out how to connect aux. inputs to the factory HU as the Uconnect uses the CD changer input. I think I found the location of a plug behind the pass. seat, but have not verified it yet.
ilovetrains said:Glad to here some people have added it, could not find a truck with it so will have to go through the dealer service area at about 400 bucks, ouch.
Not so good to hear it does not work with PDA. I am getting the Treo 650 with bluetooth and plan to use it. How did you find out it would not work with a PDA based phone??
Cali-600 said:Still works fine!
HLewallen said:Not to seem pessimistic, but what is fine? Do incoming calls mute the radio automatically just like normal and ask if you would like to answer? It appears you have the non-factory installed Uconnect (although I'm not sure - I thought all the Rams with Uconnect got the rearview mirror setup). Does that system connect to the stock radio through the CD changer port like the factory installed system does? How does the Uconnect interface with your aftermarket HU? I would be really interested in any details in how you got that to work.
