Steve St. Laurent said:
According to this thread the factory 03+ hitch is a class IV
https://www.turbodieselregister.com/forums/showthread.php?t=68022 . Surely your owners manual somewhere in it states what the hitch is rated to carry - look in the towing section. Myself I upgrade to a draw-tite class V because I tow a 35' TT that has a 900 lb tongue weight and weighs 8,500 lbs. I didn't want to mess with weight distributing bars and my hitch is rated to 1,000/10,000 weight carrying.
In the past it was the owner's manual I went by. It was what the U-Haul manager said that got me confused. I've always believed that the receiver-style hitch on our trucks was a Class IV hitch, but he referred to it as a Class III hitch while he was looking right at it. But even the owner's manual is recommending the use of an "equalizing hitch" and "trailer sway control" for tongue weights above 350lbs (page 243 in the `03 owner's manual) with
either a Class III or Class IV hitch. Here's the relevant text from the `03 owner's manual:
`03 Owner's Manual, pp. 241-242:
"A frame mounted hitch of up to Class IV rating, as rated by the hitch manufacturer, is supplied as part of the trailer tow prep package. With a Class IV Hitch, you can tow a trailer with a Gross Trailer Weight of up to 12,000 lbs (5443 kg) maximum depending on your vehicle equipment. Tongue weight must be equal to at least 10% of the gross trailer weight (GTW), but no more than 15% of the GTW.
`03 Owner's Manual, pp. 243:
Equalizing hitch are required for Class III or IV trailer hitches and tongue weights above 350 lbs (159 kg) and use of trailer sway control is recommended.
`03 Owner's Manual, pp. 244:
NOTE: The recommended tongue weight is between 10 and 15% of the trailer weight. However, the maximum tongue weight on Class III (the bumper ball) is limited to 500 lbs (227 kg), and Class IV (the receiver hitch) to 1200 lbs (544 kg) This requirement overrides any recommended GTW rating, between 10% and 15% of gross trailer weight (GTW). Additionally, the GAWRs and GVWRs should never be exceedede.
Sounds like everyone is playing the CYA game when it comes to towing and weight distribution. I didn't notice any control problems or observe anything negative regarding this 6000lb. tow. And based on the sections of the owner's manual above, I think the U-Haul manager was dead wrong in referring to my hitch as a Class III. I was pleased as punch with the way the truck handled what I consider to be a relatively light tow. And here's my obligatory fuel economy statement: When I kept my foot off the pedal I was able to get approximately 16MPG. Since I didn't keep my foot off the go pedal I got between 14mpg and 15mpg, mostly closer to 14mpg.
But with all this said, if the "receiver hitch" is a Class IV, what is the smaller receiver hitch found in minivans and small SUV's rated at? It's about 1/2 -2/3 the width of ours.
