dhill said:The book for my '05 says "for a class IV hitch, tounge weights over 350 lbs. need an equalizing hitch. "" Also 60% to 65% of the weight must be in front of the axles to sufficiently place 10% to 15% of the GTW on the tow hitch of your vehicle. " It also states that the maxium tounge weight rating for a class IV hitch is 1200#.
wtfd6 said:i definately think that u-haul is very conservative on their ratings. but it is probably for the best. i used to think that they were crazy to set the max speed for tow dollies at 45. but i found out why when a vehicle started to swing on me. just my . 02.
cwbyinjeep said:anyone here towing around 9,000lbs with the stock hitch? I am assuming the 2500 + 3500's have the same hitch. I have the owners manual, but the hitch itself has no ratings. I believe in being very safe when it comes to my equipment and eventually I will have a gooseneck trailer and all will be well. But for now I have a 12k bumper pull trailer that's usually about 9k when loaded and headed for the mountains with my Jeep. I am wondering if I should upgrade to an aftermarket class V receiver because I am doubting the stock hitch is more then a Class III if even a Class IV. Using wieght distribution really isnt much of an option, I have severe gravel switchbacks to tow around and even with 4x4 its just not a good idea to have load distribution.
Tim said:I tow my 6,000 lb off road truck on a 3,080 lb trailer with my truck. Just use a weight distributing hitch. They're made for heavy trailers.
I just don't understand why everyone hates the concept of a weight distributing hitch. I really love mine, it takes so much of the white knuckle experience out of pulling a trailer.
I bought it only because my hitch wasn't rated for the trailer weight... . and I was so shocked with the performance that I kept it.
A new trailer hitch was going to be $200, and the WD was about that (I had some of the parts already). I just bought the WD, and I'm glad that I did.
brods said:I am curious since I bought a ¾ ton truck (it even says “Heavy Duty” on the tailgate) to tow my full size Jimmy. I expected a better hitch from the factory tow package. For now I use rental yard trailers with surge brakes, where a WD setup is not an option. Seems kind of stupid to have bought a ¾ ton truck with the tow package only to have to replace the hitch to tow a trailer well within the limits of the truck!
ohnoitsyu said:AlexWV, in case you didn't know, just because the hitch you're having made can hold that kind of weight still doesn't mean your truck can legally carry that weight. For everyone's safety, please don't exceed the truck's rated capacities.
