I'm right, of course. Why do you ask???
It wasn't an easy install, maybe I just got lucky.
Blakers said:I bought a 295 and a 351. The 351 fit with no filing or cussing. Getting the old joint out required cussing and a torch. It would not budge the usual way, so I just cut the joint in half and tapped the caps in. This way there was no danger of distorting the yokes.
NAPA: you need to check your applications and update your books and website.
rbattelle said:Good info!! Where's the zerk fitting located in the 351?
JHardwick said:I'm gonna be ultra busy for the next 2-3 weeks. Has anybody prolonged the inevitable with a needle fitting and grease gun?
Blakers said:I took my driveshaft out and found the rear joint tight one way, but not the other way. In an attempt to get by until I could get a joint, I pulled back the seal lip with a large fish hook and squirted oil into the cap and kept moving it back and forth. It got a little looser as I worked it. I put it back in the truck and almost all the vibration was gone. I didn't have a needle greaser handy at the time, so just used the oil.
Blake
JHardwick said:I'm gonna try to put off changing out the joints for a couple of weeks![]()
jwduke said:Can a person lube the u-joints with one of those hypodermic needle adapters?
