At 32,000 miles, I'm getting a small squeak from the far back u-joint. It is worse under load or with the brakes slightly applied.
I jacked the rear end up and crawled underneath and turned the tires by hand and could hear it. Then, just to be sure it was not the pinion bearing, I unbolted it and, sure enough, it's the joint. When I wiggle the joint back and forth in my hand, I get a very slight squeak - kinda like a rubber on steel squeak, rather than a metal to metal squeak.
There is no play, no binding, no rust or grease coming out. I didn't have time to pull the caps to grease them, so I just put it back together. I guess it can't hurt anything for now.
Anyone had this happen? Will the warrantee cover u-joints? Is it worth it to have my truck tied up all day for an hour job I can do myself? What is the part number for these joints? What is best? Spicer, NAPA?
Thanks guys,
Blake
Thanks guys,
Blake
