u.s.gear aux trans & exhaust brake ????
Need a fresh topic
Exhaust brakes
Can you use a U S Gear aux transmission with an exhaust brake. I think I read where they dont recommend it. any clues??? #ad
2K, 2500,Laramie,Quad,4x4,3:54LSD,auto,reese 15k 5th slider, EISLEY BULL BAR,WESTIN NERFS, TA's,9000's, DD2's,PE-EZ & elbow, ISSPRO pyro & boost, Turbo Lifesaver, JARDINE 4", DTT VB,TC and COOLER, PAC BRAKE, MAG HYTECH TP& DC, onboard.
pullee #1 26' Arctic Fox 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA,VFW,SASS
[This message has been edited by JNutter (edited 01-01-2001). ]
I have been using mine on the 95 2500 and it works GREAT!! Much more control on decents. I hadnt seen any restrictions on the US Gear unit I think the Gear Vendors unit over runs (read coasts) in the overdrive. On my US Gear unit I havnt had any difficulty down shifting on a grade it just seems to pop into gear as soon as I move the button.
1995 2500 5 spd bombed. 2001 ETH 3500 stock. 1972 1066 International Harvester 414 ci diesel pulling tractor.
GONZO
US gear is a small two speed and will take exhaust braking in either range. Gear Vendors has a cone clutch which engages in OD. The helical cut on the planet gears force more engagement presure on the clutch under power and less under braking. You must be in a direct gear to use the exhaust brake. I recieved this info from gear vendors when shopping. Thought I'd pass it on.
BCFAST: I was told you can use the Ebrake with the gearvendors in direct but not overdrive, Is that fact or fiction?
2001 2500 QC, ETH/DEE,4:10s, LSD, VA Magic Box, Boost/Pyro Guages, 4" Turbo back, BD Brake,Mag- Hytec Cover, Kleen Wheels, Energy Release, 70 gal. fuel, 20K Reese. 22,000 miles on 12/19/00 (RV Dealer)
Nutter:
From my sig. you see I have both. The US Gear de-celerator works just fine with the splitter. I have the one with the waste-gate if that makes any difference. If I didn't have it I could not afford insurance, and talk about saving the brakes. I don't think I could drive without them with the loads I pull. I've got 12,400 lbs behind me nearly every day. Yes it works.
My OPINION #ad
Preston
96 3500 Black 5 speed turbo diesel, SLT, with US Gear overdrive, Rhino liner, Reese 15,000 lb. fifth wheel hitch, US Gear de-celarator exhaust brake, muffler elimination kit, Amsoil lub. , with other goodys on the way.
How do they shift under power with an automatic when pulling a grade??
do they try to fracture U joints????? I'm concerned about climbing and shifting on a grade
Nutter:
Auto! uh oh..... Cats got my tongue. GV I guess?????
Preston
I'm coming in late on this one. Just got back from a trip.
I have the GearVendors and BD E-Brake. Works fine, but have been warned by GV not to use brake when in OD. Of course you need the Autolock and pressure lock if you have the stock VB on the auto. So far I'm a happy camper.
I have forgot and engaged the brake occasionally when in OD, however RPMs were not high enough to give max retardation and had no problems (yet!).
John S. '99 QC 1T 4. 11 A/T Leather Driftwood, 50 Gal aux tank/tool box, gearvendors, BD brake/autolok, BD ISB comp, guages, BD Pressure Lock and Pract. Sol. Boost Elbow.
Just a Little BOMBed and liking it a lot.
