Just got the truck back from having the Blend Doors, actuators, Heater Core and Evaporator replaced (2 blend doors broken but replaced everything since getting the air box out is such a PITA). Truck had been sitting for a week with the batteries disconnected while the work was being done.
Started the truck and began driving. Within a few miles the CEL popped with a U010C. Truck felt sluggish and no exhaust brake. Thought it might be due to low voltage so ran a couple errands and took my dump trailer and emptied it (about 4K lbs trailer+load). Made multiple attempts to reset the CEL but it remained active.
I pulled the connector on the actuator and verified 12 VDC between pins 1 & 4(ignition on) . Read resistance between pins 2 & 3 and got 120 ohms (ignition off). Trouble shooting steps call for the resistance to be read from the NOx 1 module connector, but I couldn't get at it today and won't have access to the truck again until next weekend. I also couldn't get to the PCM connectors either.
1st question for the smarter folks here: Is 120 ohms read from the actuator connector good? I would hate to spend the enormous amount of money on a new actuator and/or turbo just to have the same problem if a wire got dinged (possible but not likely since those wires aren't exposed where we did any of the HVAC work)
2nd question: Is there any way to test the actuator to verify if it is good or bad?
3rd question: If the actuator is bad, should I replace just the actuator (my Launch does have the calibration capability). I have read a few posts where new actuators would not calibrate and a mechanic (or 2) have said they ALWAYS replace both the turbo and actuator as a matched set (not sure if this is just a recommendation or requirement)
4th question: If replacing the actuator and/or turbo is the fix, what would be the best option? Looking for a drop in unit, but keeping with my motto "Never just REPLACE, always UPGRADE when possible".
I started leaning towards ATS, however, I found 1 recommendation for it and 1 mention of quality issues so I am on the fence there. I have also looked at the Fleece Turbo/ Actuator combo, but I want to be sure it is plug and play with my (mostly) stock set up. I also read on here about the City Diesel? replacement actuator.
Apologies for book above!
What are your thoughts?
