ubcummins asks....
fender trimming
Windsheild Wiper Motor Transmission
"... . i,m putting a non intercooled 91 in a 30 foot class a both have a 727 short shaft but the moter home had a e-brake on the back of it (gone now) my question is will my :confused: yoke swap over and can i change tailshaft housings :confused: . . "
moved here for better/proper exposure/forum... . pb... :D
they both should have the sams spline shafts so why wouldnt you? the housings can be swapped if they are the same length, just unbolt the yoke and remove the 2 screws covering the snap ring so you can spread it. make sure to use a new gasket where the housing meets the case.
