ULS fuel Facts
Warning: This post is long for them who hate long informative posts.
There are some facts that we need to understand about the new fuel. The ASTM has set forth standards for lubricity. Please understand that our (I'm speaking to the 1st gen crowd as I always do) trucks have a much wider tolerance in the pump than do the new engines. The new fuel must lubricate the tighter tolerance fuel components found on the new engines.
The new fuel will act as a mild solvent when used in our trucks fuel system. It will free up some sediment. You will want to monitor the system or simply replace the filter much more often. The best method to monitor is the use of a fuel supply pressure gauge after the filter. If you choose not to monitor, then simply replace the element periodic like. If you have a gauge, then replace when the pressure drops below the specs.
The higher cost will not be realized due to the constant flux in price of the current diesel. ULSD is to be 10 cents more.
Like we will know it? I pay 2. 84 to 2. 99 and back to 2. 86 at the SAME PUMP the SAME MONTH.
BP has been selling ECD for six years. It's ULSD fuel. MOSTLY used for experiment OTR truck engines and large power plant/municipality applications. Yes it's used in Euro applications.
The lower level of aromatics can cause the older seals to shrink. The common denominator is expected to be nitrile rubber seals that have seen long service/high heat. Aged seals simply do not contain the elasticity of new seals.
The use of ULS fuel will allow for greater use of extended drain time. This due to less sulfur working past the (piston) rings. If you have the fuel rate turned way up and work the throttle like a hammer, then the added soot introduced will likely null the extended drain so it's a moot point.
Last, it's not the law to burn ULS fuel in our trucks. You can burn any combo of veggie oil/bean oil and even waste engine oil. If you have the DOC/DPF on a new engine then yeah, you HAVE to burn ULS with max of B-5 bio. and use the new lube oil formula.
We CAN use the new lube oil formulated for '07 model year engines if you so desire but it's another moot point unless you have a large (combined engine) fleet.
Scott
Bus fleet BOMBer..... 'er, Manager
Crestview LSD
Ohio
