"un" lockup swithch
1st OIL CHANGE
No air through dash vents
If having the torque convertor locked up during low transmission pressure conditions is hard on the clutch how about this? Can we install a switch that keeps the torgue convertor clutch from locking up until we want it to ? Would this work? Just an idea
Ken
1998 1/2 24 valve 2500 automatic 3. 55 alcoa aluminum wheels
Rhino Liner.
I have been considering the same thing. I know the guys that drag race with high power use a switch to prevent lock-up. I also think that a properly set up valve body will provide the pressure necessary and unlock when appropriate. You may want to post on DTT's website and see what Bill K has to say.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S Everything but leather NRA Member
The only problem with running unlocked is the transmission temps are gonna go through the roof. The stock converter fluid connection is too inefficient.
Daniel
