2nd Gen Non-Engine/Transmission Underhood Fuse Box Diagram?
Engine/Transmission (1998.5 - 2002) edge ez
Engine/Transmission (1994 - 1998) Not quite what I was expecting
I was wondering if anyone knew where I could find the lay out of the fuse/relay panel in the engine compartment.
I need to know because I pulled one of the large square fuses and it kicked my A/C clutch out. (the truck was running and defrost was on) The fuse is labeled as something else. (fuel pump maybe) I need to know if the cover is from another model, as it's possible a previous owner might have stuck a junkyard edition panel back on there before I got it.
IT's Fuse #6 in your diagram. The fuel pump fuse. . For whatever reason it cuts the power to the A/C clutch. It's just kinda odd that it does so.
