Coming from a bone stock truck and only moderately trying to improve performance a bit (without sacrificing too much fuel economy), I'm learning something on this board every day. Membership is not only worth the moderate admission; it's priceless!
I'm trying to UNDERSTAND what's going on when turning up the power. I want to KNOW what I'm doing and WHY I'm doing it, and my guess is other members are feeling the same way.
So here I go, and please chime in with your expert advise.
1) Although the 5. 9-liter Cummins engine is capable of much more power, ours has only 160hp at about 2500rpm because of factory settings which were based on primarily emission and warranty concerns. Right?
2) We get a better initial throttle and cold start response by turning the smoke screw on the IP in. The reason the factory didn't do this is, again, emissions concern. Right?
3) Max horsepower of 160hp comes at 2500 rmp although many stock trucks run out of steam at around 2400 rpm. What happens is that the "governator" spring inside the IP cuts off the fuel to the pump at that given rpm level. Changing the screw to a "better" one will allow fuel to flow beyond that rpm point and the Cummins is well capable of reving higher, up to a point of 3000+ rpm when valve float will occur, something that can be prevented by installing "better" exhaust valve springs. Right?
4) Now I'm getting a bit lost.
The power diagram of a stock engine reads that beyond 2500 rpm the power curve falls off rapidly. If the fuel is turned up, and if thanks to setting and governator spring the engine reves higher, will the power also climb up, i. e. , 160hp @2500 rpm will turn into 180hp @ 2900 rpm or what. Or not?
5) Spoolup.
I understand that a smaller turbo exhaust housing will allow pressure to build up faster, thus the turbo will spool up quicker, hold boost earlier, i. e. , lower in the rpm range, and--since there's no wastegate--run with somehow higher boost in full song. The 16cm2 housing is a great compromise since it allows spooling up quicker but will not allow the boost to climb to levels where it would potentially harm the engine.
Question A): with more boost coming in earlier, is the power output of a 16cm2 housing at, let's say 1700 rpm also higher than it is with a stock 18. 5 or 21cm2 housing?
Question B): All things being equal, except for a smaller housing. Since at 2500 rpm the smaller housed engine would make more boost, is there also more power?
6) Injectors
"Bigger" injectors flow more fuel. But if you install Bosch 190 or POD injectors, and left everything else untouched, wouldn't they NEED more fuel to begin with? HOW can they make 40hp or more power?
5) Spoolup.
6) Injectors
