Unknown codes on 04.5
De-Carbon & Other Dealer Maintenance
Cat Restriction??
Hi guys, just got my TST pmcr installed :D , waiting on the sps66.
Now my code questions I'm showing p0336(I've had that one with the banks box, crank sensor, and that one throws the check engine light)
Now for the ones I can't find, p0973 and p0882. These codes were present without a check engine light and the p0882 doesn't come up on the dash after the three key cycles. But if I turn the key off and right back on one more time it shows up along with the other two codes.
Any ideas? As always your help is very much appreciated!!
Thanks Rick
Thanks Rick
P0973 SHIFT SOLENOID (A) CONTROL
P0882 TCM POWER SIGNAL LOW
P0882: This is a nasty code remove TST and fine the cause. With the Banks you should not have set any DTC"s if it was install correctly,Those Two DTC"s have no relationship with TST. You may have Hack something.
