Engine/Transmission (1998.5 - 2002) Upcoming dyno day.Will smarty help #'s or not?
I have my comp at edge getting the drag upgrade as I type. With my setup would I get better #'s with or without the smarty? The reason I ask is the runs are $40 for the day not sure if he will give a discount for multiple runs. If he will do a discount on them for multiple runs I will do it. I really want to make 4 runs.
1-comp off and no smarty
2-comp 5X5 only
3-comp off smarty #9
4-comp 5X5 smarty #8
Only if he will give me a break will I do all 4 runs, and post the info. But unless someone has dynoed a similar setup and can give pointers on what to expect or try instead.
Does anyone think I can hit 550hp 1100 lbtq?
I have been watching what people are getting with the sps62-14 with similar setups looks like 525 1050 is a good range for them. I have the Silver 62 which should top the sps62 a bit.
I have read that running comp and smarty together actually hurts #'s. I read that people get better #'s on level 4 of comp with the smarty. Has anyone else run them seperate and as a stack in same dyno session?
John do you have a comp or fueling box also or is that just smarty only?Pretty good #'s for just a smarty.
I have a Banks big hoss fueling box. It only taps the pump wire. The combo works great on my truck.
John
You will be close to 550... . I would think, probably right around 515-525 is my guess.
billvo,
I will keep checking this post for answers, but I will be dynoing mine in two weeks. I don't have the drag upgrade on the comp, but am throwing a smarty on to see what it does to the numbers. I will have the ability to make multiple runs so I will post some numbers when i get back. :)
I've heard that sw4 & comp on 5x4 gives the most. Another guy said sw8 & drag comp on 5x5 gives the most..... who knows.
GOT-Torque said:
bbodammer, where are you going to dyno your truck at?
We're going to floor-it diesel to have some transmission adjustments made and I have demoed the smarty before. I told John to have one waiting for me :-laf
bbodammer said:
billvo,
This will be good for people to see. Our dyno day isn't until march 24 :( so we will have to remember to pull this thread out of the closet by then.
Shoot me a PM on when you will be going, maybe I will call John and see if I can dyno on the same day. I'd love to take a ride in a DTT equipped truck... ;) ;)
