Well I found the rubber line on my fuel return. Must have been one devious ba$tard who designed this.
For those that havent done this yet, the factory hose clamps are 9/32. I found a nut driver to be much easier to use rather than a screwdriver. (have to feel what youre doing. Cant really see it)
You'll want to time this with a fuel filter replacement.
IMO this has to be done from the top. You'd have to have arms like a gorilla to reach it from under the truck, lying on the ground like I was. If you have a lift, you might better off under it.
The line that came off my truck was almost 8" long. I suppose this can vary from year to year.
All in all it was . 78 and about an hour labor.
Eric
BTW The old hose didnt look all that bad. Just from looking at it I wouldnt think this was the leak. I hope it is.
98 Quad cab 4X4 2500 12 valve,5 speed,3. 54 rears, 8' bed. Michelin 275 75 16 lr-E. Boost and egt gauges but basicly stock except for a "properly adjusted" AFC. Cat in the garage. Uniden HR 2510, Texas Star 1200 amp. 63,000 Mi as of 1/27/01.
NRA life member. High power/IDPA.
Eric
