Hello to all,
There was an earlier thread on this subject and I have just installed the manual switch on my 05. The results were surprising and not expected. Maybe I can get some ideas on how to fix the results.
. I installed it with a 0-2000ohm pot and I have it set to 750 ohms.
. The problem is that as I vary the resistance on the pot it changes the temp reading on the truck as well as my edge.
. At 750 the reading is 225, the fan does come on but you have no clue as to the real engine temp unless you turn the mod off. Then it take a few seconds for the truck temp at show actual, the edge is immediate, the fan goes off.
. As you know my intent was just to turn the fan on and no side effects.
. Is there a way for this to work without the side effects?
. I am getting no engine checks, except as I increase the ohm value above 800 which produces a temp of 230 and the high temp check comes on with the bell ringing.
. I have the pot where I can play with it.
. I suspect that the fan will not turn on except at 220 to 225 because the computer is still controlling it and the pot sends it the signal that it wants. I want the fan to turn on at no higher than 210, and have a true reading on the engine temp.
Help!!!!
Dave Mc
Help!!!!
Dave Mc
