Upgraded Fuel Lines
Which is better-diabled wastegate or boost elbow
steering
While replacing another bad lift pump, I upgraded my fuel lines. I had some custom fittings machined. Metric to match the truck on one side with an O ring seal and standard fitting for 6MJ on the other side. I was able to use 3/8" hose with some gentle 90 degree swivel fittings. Next I'm going to relocate the lift pump down to the frame rail, ran outta time trying to get the truck running for South Bend install it's currently getting.
The local machinist said he would be more than willing to make these fittings in mass production if anyone is interested. The 6MJ swivels should be available almost anywhere. Or the diesel shop near me could supply them. They also had a compression fitting that slipped right over my steel fuel line on the frame rail. Very easy to install.
Let me know if you guys would be interested in the fittings and stuff. Once I get an idea of how many, the machinist can give me the price. He said he'd like to do them in batches of 50 or so, which is only 10 trucks since it takes 5 fittings to upgrade everything.
Jerry
Results
I forgot to post the results:rolleyes: Idle pressure is 13-14, cruising is 11-12, full throttle never drops below 7-8. With my old lift pump before it took a dirt nap and stock lines: idle 13-14, cruising 7-8, full throttle 0-1. Big difference! The old way after a second or two of full throttle, the light was blinkin on the SPA, below 2psi. With the new setup I set the warning light to 4psi, it has never blinked at all. :cool:
Jerry
