Having installed an extension tube on the lower end of the breather tube to direct the fumes aft, I was surprised after a 70 mile pull with the trailer to have the strong smell return. Checking, it seems that the upper end of the breather tube seems pretty loose at the back end of the valve cover where it 'disappears'... . You can't see or reach in far enough to see whether it is loose, tight, fallen off, or ???..... Is this normal, and if not, can I just take off the light cover that includes the oil cap (looks like 4 bolts) and re-attach it or tighten the connection ?. . Obviously I want to avoid visiting my local ***ler if I can. TIA. . Gerry
