Doc,
Let me start by telling you I don’t have an exhaust brake on my truck but from reading this web site I think I know how they work. The exhaust brake will activate when an enable switch has been turned on and the accelerator pedal has been released. If this is incorrect, my answer to using the cruise buttons may not be correct. Also my wiring is from FSM for my 1998 2500 and things my change from year to year. Anyway, enough of the disclaimers and on to the answer.
All of the cruise control buttons on the steering wheel connect to the PCM on the firewall, using only two wires. These two wires are routed through the clock spring at the steering column. One wire, Sensor Ground, is on connector A pin 4. The other wire, Speed Control Switch Signal, is on connector C pin 32. To identify these connectors on the PCM, connector A is black and is on the right when standing in front of the truck. Connector C is gray and is on the left. Just as a reference, connector B is white and is in the middle. These connector colors are part of the PCM. Don’t confuse them with the colors of the plugs attached to the PCM.
If you NEVER want to use the cruise control the answer is very simple. The only component needed is a relay to activate the exhaust brake and a diode to absorb the relay inductive kickback. This can be any general-purpose 12-volt relay. The reason for using a relay is the steering wheel buttons are not designed to switch much current. The relay will keep the current low to the button. I am holding one of Radio Shack’s 30 amp lighting relays in my hand so I will describe the connections to it. Cut the wire connected to connector C pin 32 on the PCM. Connect it to one of the relay coil connections, pin 86 on my relay. Connect the other relay coil connection, pin 85 to a switched +12 volt source. The remaining two pins on the relay, pin 87 and 30 are wired in place of the cab mounted exhaust brake enable switch. The previously mentioned diode can be any general-purpose diode such as 1N4001 on 1N4148, also from Radio Shack. Attach the banded end of the diode to relay pin 85 and the other end to relay pin 86. The diode may not be necessary but to be nice to the electronics, it’s a good idea to clamp the voltage spikes.
To operate the exhaust brake you will now have to hold down the CANCEL button as you let off the accelerator. The relay should activate when the CANCEL button is pushed and will release when the button is released. This takes the place of the switch previously used to activate the brake.
Now if you want to retain the cruise control functions disregard all of the above and do not cut any wires. The answer now gets slightly more complicated because an n IC is needed to “unload” the cruise control circuit. I have worked out a fairly simple circuit but I need to make some measurements on my truck and it’s raining outside. Stay tuned for the next post in a few days.
