Engine/Transmission (1998.5 - 2002) using hx35 in twin set up
Has anyone used a hx35 in a twin set up?I have phat shaft 62/14 now and my old hx35. Does anyone make a bolt on kit where a lot of stuff does not have to be fabricated if this setup has been used ?Thanks Jason
hx35 would make a great secondary turbo for twins. But that ps 62 isn't gona cut it for your primary turbo, use a ht3b or a b2.
-robert
-robert
I checked in to this before buying a single & was told that I needed atleast a 71-72 compressor to run efficiently. I was recommended a ht3b. I would just get the 62 upgraded to a super & forget the twins, because a 62 super by itself will support 600hp. If you really want twins... why not run the 62 as your small charger & ht3b for your as your primary? Just my $. 02. ;)
Thanks guys i have just had the stock turbo on the shelf for about 8 months and wondered if it could be used i have check with II to see about a upgrade to the super 62/14 i think i may go the single route. Maybe i will just put my hx35 on the classifieds. Jason
That would be the best bet... . super turbos flow awesome. I think that you will be impressed what a difference it will make. Good Luck
