Using lift blocks on a 5th wheel?
I'd like to raise my Aljo 5th wheel between 2-3". The straight axle is already under the springs and it has a subframe under the frame. Would it be safe/advisable to use lift blocks between the springs and axle to obtain the needed lift? I'm also contemplating longer shackles, or even going to 16" tires. Maybe another subframe?
I have heard of people lowering the rear of the 3rd Gen. Can you get the smaller block thru the dealership?
Thanks for your advice. .
Skip
Skip
