Just sharing; being a old sports car guy from way way back I've always liked the little Mazda Miata. Problem is it's known as a girls car which is generally not a good thing. They drive great, are one of the very best engineered and made cars to every hit the road and most importantly, the top goes down. BUT, this is America and you can have a V8 and that dose of testosterone that's needed. The two common "man" engines used in upgrading T levels are Ford 5. 0s (302 to my generation) and the LS series GM engines.
The good news is total weight increase is less than 200 lbs and weight bias goes from a perfect 50/50 to a very very OK 49/51. My car weighs 2540 lbs with a 1/2 tank of fuel and me in it. Weight difference is about like having a passenger in a stock Miata.
My humble little car has a 90 mdl. Ford 5. 0 from a 90 Mustang GT, currently bored 60 (ultrasound test said it's good at 60 over) making it a 310, running the stock GT roller cam, AFR 165 aluminum heads, Edelbrock Performer intake, 625 cfm Edelbrock carb (knockoff of a Carter AFB) and modified 1 1/2 headers though 2 1/4" dual exhaust. Transmission is a Mustang T5 from the donor car and the rear is still Mazda Miata IRS looking, but sporting a 8. 8 center section (rear end) from a 1992 Thunderbird. Gears are 3. 08 posi. Axles are from Factory Five Racing, designed and manufactured for their excellent Cobra replica cars and luckily work in this application with a few mods to the rear swing arms and hubs.
I've just re-installed the engine after pulling it to do a mild wire tuck (remove unnecessary wires and hide the rest), painted and detailed the engine compartment, installed the new AFR heads and a new clutch along with a set of Scorpion roller rockers.
And yes, these little cars are as good as you might imagine, better likely. Pull like a jet leaving the runway (I truly think my pretty much stocker will run low 12's or better), gets in the low 20 mpg's on the road and once properly sorted out, just as dependable as a stock Mustang or Miata.
