I just got the OK to post email... so here is the info!
Byron,
Thank you for your enquiry.
The P0606 code is a "ECM Hardware Error" code and can be caused if you drive the unit on full power with a cold engine.
The best and easiest way to avoid this code is to only use the half power setting until the engine has had a chance to warm up a little when you first start driving. This code will not usually set an engine warning light except on Californian spec vehicles.
Regards,
Phil Mowatt
Senior Technical Representative
-- email address removed --
Tel: +44 (0)1344 777 553 / Fax: +44 (0)1344 777 557
The contents of this e-mail may be confidential in nature and is a copyright work belonging to van Aaken Developments Limited. This email may not be copied or disseminated without the prior authorisation of the author, whether by forwarding or copying this email in reply except as stated below. The recipient of this email may reply to the author with a copy of this email attached but may not copy other addressees. This e-mail is intended for the above named addressee only. Should you receive this e-mail in error please contact us at -- email address removed --.
Sent: 02 September 2004 00:10
To: vanaaken
Subject: VA C3. 2 for 03 Dodge ram
I have a Van Aaken C3. 2 box for my 03 Dodge ram that I purchased from Piers Diesel Research in Surry, BC. When I set it to the 100% setting I get a P0606 code in the computer. What causes this and is there any way to fix it?
Thank you.
Byron Haner
