VA may be going bad!!
U-Joint Installation
The Terror of LA Freeways
D. What is your VA doing? Mine went out at about 10k miles, check engine light went on and engine wouldn't run above 1500 RPM. Code indicated ECM not communicating with fuel pump.
Sent box back and they replaced it with no problem.
Now it seems I'm getting alot more smoke than I'm used to seeing. Could this be a box problem also? :rolleyes: :rolleyes:
Well i get a lot of smoke,but I have no engine lights on,it just seems to cut out,but when I take it off it seems to be ok,fuel pressure is good. .
I do not have the VA as I have the EZ on my truck. I have noticed since the weather is warmer my truck has been smoking more lately as well. I have not check engine lights or low fuel pressure either. I think it because either I am shifting to soon or my right foot is getting bigger and heavier :) .
You might be right about the heavy right foot - - - wife had something unkind to say about that today!
D. if you've disconnect the box, and the problem disappears, sounds like a box problem.
