2nd Gen Non-Engine/Transmission Vacuum disconnected -where does it go?
Hi, I found the problem I was having with No cruise, No 4x4 Drive, No vent controls. There was no vacuum to any of theses. I started at the pump and discovered that about 16-18" from the pump there is a rubber connector. But for the life of me I can not find where it connects. Any help is appreciated and maybe a vacuum diagram layout would help too.
Thanks guys, Snow coming and I need the 4x4 drive. .
Should connect to a plastic manifold that runs just under the cowl lip that is buried in the large bundle of wires - just to the left of the brake booster when looking in from the grill.
After 8 years this post is still viable. Had exact problem.
Found vac line laying on frame rail, would not have found disconnect point if not for this post.
It doesn't take much for that line to become disconnected.
I always check it after every fuel filter change, and have always found it disconnected, no matter how careful I try to be.
