Vacuum ports for air horns
JRE Fuel system = Lower ET and Higher MPH
12 Valve 215 HP Injector Deal #2
Can anyone tell me where the vavuum ports are located on the Cummins B engine?? Seens as if I seen in a post that they were located somewhere behind the brake booster. Just hung a set of Hadley twins on the bracket behind the bumper on the passenger side(same bracket the electeic horns are hung on the drivers side. I have a vacuum operated compressor and will need a vacuum port to connect it to. Any help would be appreciated!!
I do this all the time - I forget to say that the truck is a 94 Dodge 3500 Dually.
[This message has been edited by Bob Ellithorpe (edited 10-03-2000). ]
Bill,
Look right in front of your power steering pump. There is a hose coming out of the side of the vacuum pump. The vacuum pump is gear driven and the power steering pump bolts to the back of it.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,BD valve body,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
