Vacuum Pump BLUES!!!!!!!!!!!
Fuel Filter Replacement
Heaviest load in bed
I called my local Dodge dealer today and asked for a price for a vacuum pump, then I got the BLUES!!!!!! He said, "$900. 00 some odd dollars". Has anyone rebuilt a vacuum pump or know of after-market pumps for sale.
Any assistance would be appreciated. Thank you in advance.
Les Ewen (CajunCummin')
Les, I know that some folks who have looked into mounting a Cummins air compressor in the vacuum pump's location have found that they can get by rather inexpensively with a 12 volt vacuum pump. Like $800 cheaper than what you were quoted.
The Ford medium duty F650 uses an electric
vacuum pump to power the a/c vents. If your Ram has hydro boost this will work well.
I am in the process of collecting the parts to install the Cummins air compressor where the steering/vacuum pump currently reside.
I think when I priced mine at a Federated Auto Parts store it was 315 or 390 dollars. They both sound right #ad
It was rebuilt and it was like 250 for a core but there is already a vacuum pump on there for a core so you won't have to worry about that.
[This message has been edited by Big_Bad_Dually (edited 04-26-2001). ]
Just why do you need a new vac pump?????????
Best sell the thing tomorrow!!
By chance do you have no vac supply and the hose from the block area look more flat(sucked in)than round???
96-3500 SLT EXT. CAB AM/FM/CD-RINO LINER. D-CELERATOR EXH. BRK-RED LINE VAC. OVER HYD BRK CONTROL- AIR BAGS W/HVY DUTY AIR COMP. PUTCO S/STEEL DEEPBOARDS FRONT TO REAR. REESE 20K 5TH WHEEL & GOOSE -REESE 20K HITCH BELOW W/17K RECEVER. CLEAR COATED & SOUND DEADINGING &UNDER COATED 5 SPD/W 4:10 MCHLN'S 235/16'S UNIDEN PC76/WEATHER-WILSON 1000 MAG MOUNT ANT. 4 WHL ANTI LOC BRK SYS.
750,000 miles
Just how much would an air compressor set up cost for our trucks??
Mac
95 Ram 2500 Auto Std Cab, Cat & Muffler Fell off, New Guages, 130,000 miles.
Bombed-to-be!
