Just had a couple questions about fixing a small oil leak around the vacuum pump.
First, I was wondering if it is all possible to remove the Vacuum/PS pump assembly from the bottom of the truck? I noticed the PS gearbox is somewhat in the way, but if that is removed can I just drop it down instead of pulling it out from over the driver side fender. My truck is lifted pretty high so pulling it out from the top would be kind of a PITA, but if I can't do it form the bottom then I guess I will have to live with the PITA.
Also, how many seals are there for this job? I was reading up in my service manual and it stated nothing about a vacuum pump seal or PS seal, only the gasket on the back of the gear case and the o-ring that goes around the coupler adapter on the vacuum pump side.
After searching and finding some good info I am gonna get the pump seal kit either from cummins or the fixinrams site, but in the kits they include two seals, an o-ring and a the gear case gasket, so my question is, should I replace all the seals along with the o-ring and gasket or just leave the seals alone if they don't appear to be leaking?
Overall, the job seems easy from the descriptions in the service manual, I am just looking for an easy way to remove and install the assembly. To me it looks like removing the steering box and dropping the assembly down seems the easiest. I am only saying that cuz I just got my Piers intercooler boots on and I don't want to have to go through that pain again of removing the intake tube and re-installing it.
Thanks, Joe
Thanks, Joe
