It just comes down to isolating sections one at a time. Our trucks are pretty simple, the vac pump is located on the drivers side, front of engine. From that a line comes off and runs to the firewall, there if feeds three basic areas. First is to the cruise control, second to the inside HVAC controls, and third to the transfer case and front axle disconect. If you have a vacume tester kit, like something they sell at sears, you just unplug one section at a time and check it out. Once you find the bad section, start going thru it till you find the source of the leak. Don't be supprised if you find several leaks. The two biggest problems are old or rotten hoses, and vacume motors with bad bellows. Seems like alot of people have a problem with the four-way block located on the transfer case, and the de-froster vacume actuator under the dash. Oh, before you do anything, check the vacume reading at the pump.
