Valve Adjusting
TAG in a 1st Gen?
Need LOTS of advice
I want to run the overhead on my 92, its never had it done, the people I got it from serviced it well, but never done this, what is the precedure for this, I looked in the service manual and its alittle vague. Use the timing pin to find TDC? On my 03 I look at the balancer, can you not do this as well? And my 03 service manual said make sure #1 cyl. valves are loose prior to adjustment, if not rotate 180 deg. Its doesn't say anything about this on the 92. Is this same precedure for my 92? :confused:
On the new one, you can have the marks on the damper lined up and actually be on #6 TDC. That is why they say the #1 rockers should be loose. If they aren't, you need to rotate the crank 1 more turn. The timing pin on the 12v will only line up with #1 TDC.
Travis. .
