Valve Adjustment on 93' W250
Lots of blue-white smoke
Getrag Speed range per gear?
how difficult is is to do a valve adjustment on these 12valves on your own. im thnking my truck really needs one and am wondering how tuff it is.
how much will a shop usually charge to do one on our trucks?
ok then. thanks for the advice and the willingness to help. id gladly get you a 24 pack of mountain dew. hahah
thanks for the link too.
(by the way, great quote in your signature!)
Do the last "short Version"
Use the last "short Version. " I've done it that way, quick, easy, minimum patients needed. Follow the directions carefully. Get a new gasket set, it's worth doing it right the first time:cool: I've been using the same method on my bug for over 18-years every 3K miles. Works like a champ:-laf
Patrick.
if you dont mind me asking... why do you adjust the valves every 3k. i thought every 25k er so was pretty standard?
thanks for the advice.
