Engine/Transmission (1994 - 1998) Valve Adjustment
Engine/Transmission (1998.5 - 2002) Sick truck
On the 12 valve you can use the alternator nut to turn the engine. The hole for the barring tool is on the passenger side facing the front. There is a black plug in the hole you will be looking for
The barring tool goes into the bell housing on the passenger side. There is a hard rubber plug that needs to be removed to slide the barring tool in. It helps to put some assembly lube on the splines of the tool first
