Just checking to see how many of you out there do your own valve adjustments. Mine is due for one, think I hear some of the rockers tapping a bit. Cummins Northeast wants $175 for a valve adjustment. Not sure how much of that is for the gaskets. I have a set of feeler gauges (used to adjust the valves on my dirt bike). It seems that all I'll need is a set of gaskets and a couple hours of time to do this. If I remember correctly, the engine should be cold prior to the adjustment, intake 0. 010" and exh 0. 020". How about the torque spec for the adjuster nuts? What's the best way to crank the engine around by hand?
Sean
Sean
