I just did mine again yesterday. If it's your first time, accurately locate #1 TDC, (maybe with the timing pin) and mark it someplace on your damper so you can find it the next time. After that, close enough is good enough, you don't need to use the timing pin again, it's just for timing the pump anyway. Now you can adjust what ever valves you are supposed to in this position, then rotate the engine one revolution until your TDC mark lines up again & adjust the rest of them. You can turn it over with the alternator nut, or lay on your back, and rotate the engine by hand using the damper. To do it that way, it's helpfull to put a punch mark or paint dot at the 6 o'clock position on the damper so you can see it while under the truck. When you adjust the valves, back the lock nut off, and run the screw down with your fingers until you get the proper "feel" on the gauge, and then snug up the lock nut. Sometimes the screw will tighten up on the feeler when you tighten the nut, so re-check it, and work with it until it feels the same as the rest of them. I have a couple on my engine that give me trouble, and I have to hold them with a screw driver while I tighten the nut, and still have trouble getting them right.
