Here's a compliation of instructions for adjusting 24-valve engines - works for me:
Winter finally broke here in Michigan (70 degrees today - was snowing last week) so I finally was able to get around to adjusting my valves since I have 100,000 miles on the truck. Here's what I found - intake valves were from . 012-. 015 (optimum is . 010 (. 25mm) - spec is from . 006-. 015) and exhaust valves were . 021-. 024 (optimum is . 020 (. 51mm) - spec is from . 015-. 030). I was blown away that they were still within spec after 100,000 miles - and I haven't been exactly easy on the engine . I set mine slightly tight at . 008 (. 20 mm) on the intake and . 018 (. 46mm) on the exhaust. A note to anyone adjusting theirs - there is a lot of play in the Y from the camshaft to the valves on the 24v engine. I adjusted mine and then cranked the engine over and then rechecked them - it took about 6 times of adjusting them before the numbers were consistent on the next rev (I've adjusted TONS of valve trains over the years BTW). I continued to adjust them until I was able to get a consistent reading for 2 revolutions after I adjusted them. -Steve St. Laurent –
LSMITH: I have played with settings all over the map and found with my combo . 007 (. 178mm) and . 016 (. 406mm) is the right spot, it frees up the top end tremendously. . 012 (. 305mm) and . 025 (. 635mm) has great low end if that is your bag... ... .
TOOLS NEEDED
22mm or 7/8 socket, and long-handled ratchet, for turning engine via alternator
15mm ratchet wrench or socket, for removing valve cover
14mm or 9/16 wrench and socket, for adjuster nuts. 5 mm hex key, for adjusters
Instructions from Chad Sheets
Back all the adjustment nuts off on all rockers, then run them down with your fingers until they touch (you will only be able to run down the rockers with no tension on them... the ones with tension will have to wait their turn on the next round when you rotate the engine 360 degrees. Zero the gauge out and adjust for ever how many mm or whatever measurement you want to use.
1. Put cyl #1 on TDC by using the TDC mark behind the crank case breather on the front of the engine. You will have to remove the breather... I believe it unscrews. You will see "TDC" stamped at 12 o'clock inside the case and a mark on the fuel pump timing gear. Put that mark on the 12 o'clock TDC position.
2. Remove the valve cover, and mark the following INTAKE valves with a paint marker, 1,2,4.
3. Now mark EXHAUST valves 1,3,5. with the paint marker. You should have 6 rockers marked now.
4. Adjust the INTAKE valves somewhere between . 15mm and . 38mm. , I shoot for the middle of the road . 25mm. (per LSMITH - . 20mm)
5. Adjust the EXHAUST valves now between . 38mm and . 76mm. , again I shoot for middle of the road about . 57mm. (per LSMITH - . 40mm)
6. Give all the rockers a good wiggle before removing the gauge to make sure all the play is out of them.
NOW ROLL THE ENGINE OVER 360 DEGREES AND ADJUST THE 6 ROCKERS NOT PAINTED.
