TWest said:Some have try to remove the VB ,and in the Process Bent or install the sprag Rod incorrectly,also when removing the E-clip it landed in behind the front band ,When turning it fell into the retainer and was destroyed,also the lever assembly is easily Broken. Also your stock TC won"t Last Long If you Add HP. Removing the Gov/Pressure solenoid is easy.
