15mm bolts, torqued to 18ftlbs. The valve cover gaskets are reuseable. If you don't have alot of miles on them and or they are not cracked, dry rotted or leaking I wouldn't change them. Don't use silicon on them, not needed. They run about $4. 00 from Cummins. I'd only use the Cummins gaskets. I've never changed the o-rings for the bolts on my two, but I would like to. But even with them dry rotted and falling apart, they've never leaked. Most of the time when the valve cover gaskets leak its because they were not torqued to 18ftlbs.
