I posted ealier this month about a noise I have. It's loudest when the engine is under load; especially when I'm on an onramp and it just shifts into overdrive. When I ease off it seems to stop. Maybe hear it a little bit. I first described it as if a screwdriver is resting on a turning shaft but it seems to have a high frequency pitch to it. Would loose valves cause this noise (worse under load). It sounds fine at idle. It sounds as if its coming from inside the dash centrally. Like maybe coming from the back cylinder. I removed the serpentine belt and all the bearings seem fine(tensioner, alternator, water pump).
