Valve spring chainge`
BUG Cleaning tip
Manual transmission temp: do you need to monitor it?
Hi all, I orderd a Pac-brake today and will be installing it this weekend. I dont know if I will have time to install the valve springs and butterfly plug befor I leave for MM. Anyone have any hints on installing the springs? What spring compresser did you use?How long did it take?
Thanks in advance.
Bob V
'97 CC 5spd 4. 10 5spd 315/75 16,Bushwacker,TST 280hp.
I used a Snap-On spring compressor. The kind that grabs the spring from the bottom and you crank down on it and it pulls it up. It took me about an hour and a half to do all six. You only have to move the engine three times including the first, because one and six, two and five, and three and four are done at the same time as they are at equal piston heights. Things I'd have on hand are a small telescoping magnet for the keepers, and lots of rags to cover all the holes with so that if you drop a keeper it will stay within reach. The other thing is head bolt torque. The popular way now is to give it 125 ft/lbs and that's it. But the 13mm bolts only get 18 ft/lbs. Best thing is to set aside twice the time you'll need just in case things go awry.
Chris Timochko
*Association of Diesel Specialists Certified*
AUTO WURKS DIESEL R&D TEAM
1997 5sp 4X4, Rhino Linings, Espar Heater, A. W. D. HX40 turbo, ATS 3pc Manifold, BD 4" Brake, Marine Compression, A. W. D. Custom Tuned Injection Pump, A. W. D. Intercooler, A. W. D. /Mallory Fuel System and Braided Stainless Lines, A. W. D. 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, A. W. D. Water Injection, NOS Diesel Kit, A. W. D. 6" Chrome Exhaust System, BD No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. 15. 50@97mph on Goodyear All-Terrain tires.
Project U96 - 1996 3500 2WD racer. A. W. D. Marine Ultra Low Compression, A. W. D. Teflon-coated Pistons, A. W. D. High Lift Camshaft, Ported and Honed Cylinder Head, Intake and Exhaust manifold; A. W. D. HX40 Turbocharger, ATS 3pc Exhaust Manifold, A. W. D. Water Injection, A. W. D. Custom Fabricated Fuel System, Race Spec A. W. D. /BD P7100 Injection Pump, A. W. D. Custom High Flow Fuel Injection Nozzles, BD Auto transmission and Custom TC, Weld Draglites, Goodyear Eagle Drag Slicks, 5" Single Stack Through The Bed, Mag-Hytec on Rear and Transmission. 11. 54@115mph
Bob:
The snap on tool Chris referred to is mfg. by KD and is available at most Napa's and other good parts stores. Mine cost about 54 four or five years ago and I think i saw one recently for the high $30's.
I don't remember the part number.
Mr. 5. 9 gave you the rest of the short cuts, replace your gaskets while your at it and give yourself a harty pat on the back.
Enjoy MM.
Andy
Bob, look in the archives Chris(diesel5. 9) gave some awesome instructions ! #ad
I used his instructions and did not have any problems took only an hour and a half. Chris said to put rags down and have a magnet ready he is telling the truth really cover up those holes well !! good luck #ad
96 2500 4X4, SC, SLT, 12 valve,lost kitty, silencer ring gone, 5SP 3. 54. dana 80, Pac Brake with 60 pound valve springs, line-x liner, soon to come: Auto meter ultra lite boost and pyro gauges on A pillar,
My KD tool has #3271 on one of the arms. On the box from Pac containing the springs and plug, they claim you get about 30% more braking effect with the 60 psi springs.
Thanks for the replies! Got the spring compressor and stick shift switch at NAPA today. The only compressor they had was a KD 2078 but it looks like it will work and it was only $31. It took a little wile to find the part number for the switch,#PP6490 ($11. 50), they didn't have the harness so will have to make my own. Thanks again!
Bob V
The bolts holding the towers down double as head bolts !! #ad
