Actually, the ball is rolling in the right direction here. The P pump engines (94-98) do what they do as good as they do because of the high pressure that the P pump puts out. No matter what, the rotary pump cannot put out the pressure that the inline pump can, nor can it last anywhere near as long. For those without a physics degree, the rotary pumps feed fuel for all six cylinders through one valve. On the inline pump, there are six feeding six, each of which is doing 1/6th the work to get the same job done. In Europe, the ISB is running with common rail injection, which is the highest pressure injection available and is by the Diesel Industry's standards--the injection of the future. In 2003, I believe that the ISB will finally make its mark with common rail injection. Volkswagen, the leading producer of Diesel engines worldwide, has been using common rail technology for years now in Europe and the horsepower and fuel economy are second to none. And as long as the computer industry is still alive, they can and will be B. O. M. B. ed.
Chris Timochko
*Association of Diesel Specialists Certified*
AUTO WURKS DIESEL R&D TEAM
1997 5sp 4X4, Rhino Linings, Espar Heater, A. W. D. HX40 turbo, ATS 3pc Manifold, BD 4" Brake, Marine Compression, A. W. D. Custom Tuned Injection Pump, A. W. D. Intercooler, A. W. D. 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, A. W. D. Water Injection, NOS Diesel Kit, A. W. D. 6" Chrome Exhaust System, BD No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. 15. 50@97mph on Goodyear All-Terrain tires.
Project U96 - 1996 3500 2WD racer. A. W. D. Marine Ultra Low Compression, A. W. D. Teflon-coated Pistons, A. W. D. High Lift Camshaft, Ported and Honed Cylinder Head, Intake and Exhaust manifold; A. W. D. HX40 Turbocharger, ATS 3pc Exhaust Manifold, A. W. D. Water Injection, A. W. D. Custom Fabricated Fuel System, Race Spec A. W. D. /BD P7100 Injection Pump, A. W. D. Custom High Flow Fuel Injection Nozzles, BD Auto transmission and Custom TC, Weld Draglites, Goodyear Eagle Drag Slicks, 5" Single Stack Through The Bed, Mag-Hytec on Rear and Transmission. 11. 54@115mph
