valvoline prem. blue 2000 synthetic oil
Bed liners again; or Herculiner vs Line-X
Omaha Area Advice-
OOPS! forget my last post Steve. I just read your next to last post explaining the PB2000. Crap, I just switched to it too! Now, if I could only find a source for the Mobil Delvac 1 I'd be in business. I have a hard time believing Vaughn can easily obtain it in Eastern WA. although, I can't seem to locate any in Western WA. HELP! Who the heck sells this stuff???? The issue of oil in my Cummins, and procurement of same is really ******* me off! #ad
I was using Red Line although, it was just too expensive at $7. 50 per quart x 11 qts. for the 6,750 mile oil change interval I had it in for, three different changes worth!!!! I intended to adopt a 10k oil change interval however, oil analysis results revealed high silicon levels, most likely due to the poor design of the OE air box seal. The OE Fleetguard/Dodge, Fleetguard, and XLerator (two-stage foam) filter elements ALL exhibted relatively the same silicon levels. I switched to the K&N RE-0880/25-0880 filter/pre-filter at the same time I switched to the Valvoline/Cummins PB2000. The next oil analysis should substantiate my suspicions.
'98. 5 2500 QC 4x4, (BLACK) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X bed liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, PIAA Dual Sport 900 auxiliary lights and Super White bulbs, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, Bosch 275 hp. injectors, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, "Scotty Air System", BLACK '00 valve cover, Hitco/Geno's exhaust blanket, Femco/Geno's EZ Drain oil pan plug, Banks Stinger 4" dia. stainless steel exhaust system, BD LV V10/Cummins hybrid TC and valve body, BD modified transmission front pump and PressureLoc, plus many other trick modifications
