Tone Ring Mod with VA-C3.2
Blakers,
The Tone Ring Mod basically adds about 2 deg's. of timing. Pretty much the same thing as the Rockteck Mod but, cheaper because you do it yourself.
The TR is found behind the crankshaft (lower) pulley. It sort of looks like a circular saw blade with carbide tips. The crankshaft sensor is the green, plastic piece that is mounted on the engines right side. It's situated right next to the tips of the TR.
The first thing you want to do is take the serpentine belt off by taking the pressure off from the belt tensioner. Once the belt's off, you have to loosen the 4 bolts holding the pulley & TR on. If you have a stick shift, put the truck in a higher gear with the emergency brake on & that will keep the engine from turning over while you are trying to loosen the bolts.
On the auto's. I've heard you have to remove the trans. inspection plate & jam a screwdriver or some other tool into the flywheel gear teeth to keep the engine from turning over.
Once the bolts are removed, remove the pulley & the TR noting how the TR is positioned on the crankshaft. You will notice five holes on the TR. Four holes that the bolts go through & a smaller hole that the alignment pin goes through. When you look at the front of the TR, you want to remove about 1/16" of metal from the left, counter clockwise side of the smaller, alignment pin hole, only. That allows the TR to slightly rotate clockwise once it's re-installed.
I used a "rattail" file to remove the material from the hole. It's pretty easy to do.
After elongating the hole, re-install the TR & pulley 7 finger tighten the bolts. Loose enough that you can rotate the TR. Rotate the TR as far clockwise as you can & then tighten the 4 bolts. The bolts need to be tightened to about 32 ft. Lbs. & then another 60 deg's.
Re-install the serpentine belt. If you have an auto. remove the tool from the flywheel & re-install the inspection plate & you should be ready to go.
In 40-65 mph. timed runs, I noticed about 1/2 second improvement, with the TR Mod.
With the VA-C 3. 2 on the high setting, TR Mod & an AFE ProGuard-7 air intake system, my 40-65 mph. runs (all runs done in 5th gear) dropped 3 seconds from completely stock.
I think "swiss-cheesing" the stock airbox is, probably, the most cost efficient way to add more air into your system. My "not-so-scientific" testing showed only a 4/100 sec. improvement with the AFE system over the completely stock airbox. That's not much of an improvement for the amount of money these air intake systems cost. I'm not trying to "knock" AFE or any other air intake system company, I just haven't noticed enough improvement to warrant their relatively high costs. Their products "look" well built, to me.
For what it's worth, these are my experiences with the performance products, I've tried.
Hope this information helps.
Joe F. (Buffalo)
