Big P said:Is anybody running this pressure box on an 05? There website says only 03-04 trucks.![]()
Big P said:Thanks for the info. For a pressure box I like how it is designed, ramps up pressure quickly without exceeding stock max pressures. I was looking for something to go with my TST to liven it up a bit.
Tomeygun said:Not that VA does not make good HP and stuff, But I tested one on the dyno against my EZ:
https://www.turbodieselregister.com/forums/showthread.php?t=144722
JUst an FYI, you'll be leaving some HP on the table for sure.
SKneeland said:i dont mean to highjack the thread, but tomey have you dynoed the old tst/ez combo against the new tst w/fuel pressure?
Big P said:I checked out the link, and you're right, 50 hp is a big difference on the top end. But what did your SOTP dyno tell you? :-laf My truck is usually set with the TST on 4x4 95% of the time. Although the Smarty woke the bottom end nicely, I'm not using it any more. It just seems to sound, feel, run the best with just the TST for an everyday driver. I was considering an MP-8, but I keep hearing big pressure is hard on injectors and injector bodies. I've given up on big hp for the street, I just want reliable power I can use every day. That's why I was looking at the VA.
Tomeygun said:... Just an FYI, you'll be leaving some HP on the table for sure.
Big P said:I think I'm going to give this box a try. I remember reading in the TDR magazine that this was the only pressure box that didn't adversely affect the injectors too.![]()
Tomeygun said:I think you are right, I think its max PSI is around 23k...
Diesel Power said:26000 to be exact![]()
Tomeygun said:Even on the VA3. 1? I though thier claim to fame was "no pressure over stock max"?
I know my TST with TX has shown 27100 many a time... Gotta love that Rail pressure gauge!
