Hammer
Why would you want to advance the timing on the higher end of the rpm band?. It would stand to reason as the charger/chargers get better lit and cylinder pressures increase greatly you would want to retard the timing some which would help lower cylinder pressures and allow the motor become more efficent. To take a competition built P-Pumped motor,which many are already at or above 45 degrees of timing and advance it even further,would create huge cylinder pressures and possible failures or breakage. Just curious???... . Andy
