VB/TC questions
adjusting front wheel bearings
oil overflow bottle?
I am considering upgrading to Bill K. VB/TC. When using 2nd gear lock-up during deceleration does this provide more breaking capacity when going down steep hills? Would this be a safe way to retard speed when pulling a 5th wheel or would the EGT's be in trouble? My truck is completely stock at this point. Would the VB/TC be a noticable improvement? I am planning on mild BOMBING later (EZ). Any comments will be appreciated.
2000 RAM, 2500 HD, SLT Quad Cab, Cummins ISB, Auto, 3. 54 LS, Trailer tow group, Fog lights, Rhino lining, Geno finger touch oil drain, Reese 15K hitch, 2001 30' Cardinal double slide 5th wheel.
beartrace The Vb & Tc will be very noticable at stock levels it will make you smile. #ad
I would call Bill with your 2nd gear lock up
question since I cant comment.
But I can attest to Bill and his crew are very professional and the product is second to none .
Call Bill 1-800-922 -7782 Bill will give you an honest opinion to your needs
I have a lock up torque converter and one of the best things is the ability to lock up second gear. This is great for going up hills and coming down them with the exhaust brake on. Mine is not from Bill but from Dunrite.
You will not lock up the DTT TC in second for acceleration or hill climbing as the fluid coupling is so tight you will not need to stress the l/u clutch. For exh. brake, his TC Saver will take care of everything.
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T w/ DTT VB, TC, TC SAVER and AUX COOLER , REESE 15k 5th slider, EASLEY BULL BAR, MAAP NERFS, BFG-TA's, 9000's,TORQUS MAXIMUS 505 lbft ECM, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", PAC BRAKE, MAG HYTECH TP& DC, AFE filter, GEAR VENDORS OD, TAYLOR WING onboard.
pullees:
#1 y2k ARTIC FOX 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
